pitch of hip end
1 Jan 2005
I'm designing an extension to a semi with a hip end to the roof and need to know if the pitch of the hip end can be steeper than the front and rear pitches. I can draw it ok but the existing pitch angle is 35º, the end would be 45º. Will this cause problems when the roofers come to lay tiles?
thanks
So long as you don't intend using bonnets or arris hips, rather use the ridge hips then you will be ok.
Be a challenge to cut the roof or are you having trusses?
The jack rafter splay plumb cut (top cut to the jacks or commons on the hip blade) will be a nightmare because it will not interject at 45 degrees rather it will be an acute angle.
Irregular hips shouldn't be a problem for either the roofer or the carpenter.
Cutting an irregular hip is no more difficult than cutting a regular hip. You just have to do the maths and cut the correct angles.
Having different slopes on a hipped roof does cause carpentry problems at the eaves.
For a given projection of eaves each side, how are you able to arrange a level fascia board and guttering? A two or three degrees difference on each slope could be accommodated, but 10 deg. difference is a lot - see sketch showing the problem.
Why do the roof slopes have to differ?
Tony1851 - as I understand the OP it's the pitch on the hip plane that is different rather than the pitch rolling through along the main roof planes. If I have understood this correctly then the only difference would be in the length of the seat cut at the rafter foot which would be covered if a soffit is being fitted and therefore unseen. It's not a major issue at all.
Another option should you want to keep your pitches regular would be to put a Dutch gable in. Not sure how planning would react to this as they look quite agricultural. or you can have a raised half hip which are somewhat more common and look a fair bit neater.
Tony1851 - as I understand the OP it's the pitch on the hip plane that is different rather than the pitch rolling through along the main roof planes. If I have understood this correctly then the only difference would be in the length of the seat cut at the rafter foot which would be covered if a soffit is being fitted and therefore unseen. .
OakFramer; I was fairly certain that the OP meant that the hip face was a different pitch to the other two planes and that the variation between 35 and 45 was not in one plane.
The sketch was intended to show, in one diagram, the effect that the different slopes have at the eaves, and the consequent difficulty he would have in lining up the fascias and guttering.
With respect, I have to differ and believe pitches differing to this degree will cause the OP some problems.
There is always a knock on effect in my experience when moving out of the norm, and will certainly test your brain later on.
thanks
More info needed, interesting problem
