Hello,
I'm planning to add a new radiator to my central heating system. This is the first time I've done something like this, so I wanted to outline my plan, and ask if there any obvious pitfalls I've missed and should be aware of?
I'm in a 1930's terrace and when the previous owner made the front living room and entrance hall "open plan" the only radiator he put in was right next to the front door in the hallway, on the party wall. This means most of the heat disappears up the stairs and the living room is freezing!
The C/H is a combi boiler and luckily the drain point for the system is on the current radiator in the hall so that should be straightforward. I've measured the room and am going to get a rad with a bit more BTU/hr than what the calcs say the room needs.
I've taken up some floorboards and found the feed and return pipes (15mm copper) by the current radiator in the hall. I'm planning to put T pieces into both these pipes and send the new 15mm copper pipes over into the living room and then do 90 degree turn to hit the ends of the new rad which will be under the living room front window.
I've decided to use those fittings with a ring of solder inside each end to made my life easier. I know to make sure that the old pipes are 100% dry before soldering. I'm going to run the new pipes under the joists and attach them where required.
The only question in my mind is - does it matter if I run the new pipes straight across into the middle of the living room, and then turn at 90 degrees towards the rad, or would it be "better"(not sure why) to try and run the new pipes so that they are closer to the wall?
Any other really obvious pitfalls I should be aware of?
Cheers.
Cheers.
