Plaster cracks, or something more serious?
7 Dec 2019
Just spotted this in my daughters bedroom.
From a distance you cannot see it, but up close you can. Both walls are external and up close the color of the paint appears the same. The temp (to touch) doesn't change between the crack and other part of the wall, and it's dry, not wet to touch.
Been up in the loft and cannot see anything obvious, but I'm a big guy and lofts are difficult to move around. I was thinking if it was a leak or something it wouldn't be as uniform and in a line, perhaps.
Does this just look like a plaster crack? Where the lines are there is a slight bump.
Doesn’t look like anything to worry about and pretty common in that spot. Won’t be moisture related, you’d see a load of staining if it was
Thanks @23vc , that was what I thought. We have had some rain today and it's not got any bigger so presumably just a crack I've only just spotted today.
