plaster finish
3 Feb 2009
Gloucestershire
Hi iv have takenout a full height window and bricked and blocked up 600mm. The width is 2300x600 of blockwork on the inside and want to plaster over to finish flush with excisting plaster,I set the blocks back about 10-12 mm from plaster...can i just plaster straight onto blocks or add a pva or have to use browning 1st,,any advice welcome.
9mmBonding plaster straight onto blockwork, you dont need pva.
3mm finishing plaster to finish.
break the edges from the existing plaster and scrim tape to give you a good joint.
