    Dismiss Notice
Plaster shortage
Discussion in 'Plastering and Rendering' started by Londoner2, 15 Jul 2020.
  1. Londoner2
    Londoner2
    24 Jul 2018
    189
    Thanks Received:
    16
    Country:
  2. Sponsored Links
  3. VickyBH
    VickyBH
    26 Sep 2018
    94
    Thanks Received:
    4
    Country:
    this is ok to use, but very expansive, £25 for 10m2 coverage at 1mm, whereas multi is only £7ish for same coverage at 2mm. The finish is not as fine/smooth as multi finish, they have another 'light' version which has better finish.
    • Thanks Thanks x 1
  4. Londoner2
    Londoner2
    24 Jul 2018
    189
    Thanks Received:
    16
    Country:
    You are right, but to a diy'er no mixing involved with all that entails and you have the right consistency.
  5. Progressive
    Progressive
    15 Jul 2020
    Thanks Received:
    Country:
    Is multi finish now readily available? If not, what’s the best way of getting hold of about 10 bags?
  6. bennymultifinish
    bennymultifinish
    21 Apr 2020
    2,082
    Thanks Received:
    319
    Country:
    no . slow . find someone with a trade account with a merchant . most places will only let you have a set amount.
  7. VickyBH
    VickyBH
    26 Sep 2018
    94
    Thanks Received:
    4
    Country:
    Mixing is simple though. The difficult bit is knowing how to control the suction on wall, and how to spread plaster tight and flat whilst not leaving any marks. If you want a smooth finish you'll need at least 2 tubs (ie, ProRoll max first, followed by ProRoll light). I'd say go for it if you only have small area to skim, but if you need many tubs to get the job done, might be better off getting a pro in.
  8. Sponsored Links
  9. BigClick
    BigClick
    1 May 2018
    59
    Thanks Received:
    3
    Country:
    Jewsons, Wicks, Selco Travis et al are “looking after“ regulars. So even if a place has a delivery I can’t get any. I wonder How many of these regulars are the ones selling on ebay and Facebook at scalped prices?
    BG are posting updates now saying production is higher than Pre-lockdown. So where is it all going. Frustratingly I just have one room left to do but I am not going to pay over £30 a bag out of principal.
    Fekin old boys network and corruption. “Thistle Gate”
    • Thanks Thanks x 1
  10. darrington
    darrington
    28 Dec 2010
    431
    Thanks Received:
    96
    Country:
    The BnQ where we live, now has 5 pallets of Multi Finish, and 2 pallets of Bonding coat,, plus loads of thin coat corner beads, (2.4 and 3mtr lengths), plus Thick coat beads, Belcast beads, stop beads etc, the place, plaster wise is now booming,,, yehhh.
  11. Londoner2
    Londoner2
    24 Jul 2018
    189
    Thanks Received:
    16
    Country:
    UPDATE: Job all done, used 4 tubs in all and a bit of sanding and looks fine.
    • Thanks Thanks x 1
  12. VickyBH
    VickyBH
    26 Sep 2018
    94
    Thanks Received:
    4
    Country:
    Well done, did you use Max or Lite for finish?
  13. Londoner2
    Londoner2
    24 Jul 2018
    189
    Thanks Received:
    16
    Country:
    Lite on all walls, easier to work with.
    • Like Like x 1
Loading...
Share This Page
