Skimming
30 Aug 2017
I'm going to have a go at skimming some plasterboard in a walk in closet over the weekend and just wanted some guidance with regards to whether I can skim two walls one after the other without the first fully setting, and what the risk is of damaging the skim on the first wall whilst working on the second.
It's only a small closet, so i'm not too worried about it being 100% perfect - hence doing it myself instead of getting a pro in, and will be using Knauf proroll.
Is it simply a case of being careful not to nudge the other wall, or is there more to it than that as to why two adjoining walls should not be plastered too soon after each other?
Just be careful not to nudge but remember the corner can be filled with decorators caulk when you paint the walls;)
