Your wisdom would be much appreciated on our skimming nightmare – sorry for the length of the posting!!!
We recently purchased a 1930’s house and painstakingly stripped off all the wall paper (no steamers), the original walls (lime plaster – it think) had ‘crazing’ lines all over but were generally ok apart from the a few larger cracks here and there. As we had to remove all the old lath and plaster ceilings, we decided to have all the walls skimmed as well.
The original walls throughout the house had lots of dust, wallpaper glue and old paint residue (some of which was powdery – we’ve now been told this may be distemper?), and we raised our concern with the builder at the time but he assured us that applying pva to the walls would provide all the grip required for the new plaster skim, and his plasterer did in fact roll on a watered down pva solution onto the walls and let this dry before then starting to apply the skim.
Unfortunately however the new skim has started to blow away from the walls, in one of the bedrooms this is clearly down to the powdery stuff on the walls (the plaster simply hasn’t bonded to the wall at all - when you rub the wall behind where the plaster has fallen down, your hand is covered in powder), and in the wc where the walls had in the past been painted with gloss, the pva/plaster again has simply not bonded to the wall at all.
Having subsequently gone through the house knocking on the walls, we have found that there are hollow sounding areas in all the rooms and cracks are visible in these same and other areas – the plaster doesn’t seem to be detaching from the walls in quite the same way as yet, but is this just a question of time as we go through the warm and cold seasons?
One other possible problem is that we know that in some areas, including external walls, he has used bonding plaster to fill larger holes (for example where windows have been blocked up)…is it true that this can lead to damp problems?
It’s difficult to know whether the hollow sounding areas are blown areas of the new skim or blown areas on the original plaster? Either way, with hindsight it’s clear he hasn’t prepared the walls appropriately, including where necessary hacking away any blown areas of the original plaster. If only we knew then, what we know now!
We want to avoid wallpapering over as it doesn’t deal with the problem and as of course it becomes an even bigger nightmare to resolve any issues that arise later once we have decorated and bought new carpets, etc? So the question is, what do we do from here?
1) Do we simply hack away the areas that sound hollow (of which there are many per room) right back to the brick and then build these out with bonding/hardwall plaster and then re-skim the whole lot again?
I am concerned that we are inevitably going to miss some hollow areas and that another layer of skim on top of a layer which is probably not properly bonded in the first place is just going to cause more issues. After all throughout the house the walls had the same powdery paint and dusty surfaces and were of course prepared in the same way by the plasterer.
2) Do we have the skim layer he put on completely hacked off, then hack back any blown areas of the original lime plaster back to the brick, build these areas out, and then re-skim the whole lot?
I think this would give us more peace of mind, however, as the original lime plaster is probably very fragile, I am concerned that hacking away the whole lot (although I suspect it would come away fairly easily) may cause areas of the original lime plaster to de-bond from the brick, and then of course we have a whole new set of problems.
3) Do we do something else entirely?
Any help / guidance greatly welcomed!!
Many thanks!
Many thanks!
