Plasterboard (moisture resistant) fixings
5 Dec 2012
Hi all
Am fixing moisture resistant plasterboard to a bare red brick wall using dot and dab.
I then understand it is best advised to put mechanical fixings in to the adhesive once it had dried, is this correct? I am tiling on to the plasterboard.
Can anyone advise what mechanical fixing are best to use to go in to the adhesive? The board is 12.5mm thick
I have done a lot of dot and dabbing over the years and have never used mechanical fixings. I put loads of adhesive on the boards and I haven't had any come backs yet.... :wink:
Is that with tiling on the plasterboard aswell?
Yes I tiled my bathroom 16 years ago on top of dot and dab and they are still there,,,, :wink: You have to make sure that your walls are dry and no damp will penetrate it, so check your render and outside wall covering,,, :wink:
