Morning all
Looking to mechanically fix foil backed plasterboard to the underside of rafters on an outbuilding's flat roof, and sandwich 50-70mm celotex in between the rafter and plasterboard (insulate under the rafter). In addition to 100mm friction fit Omni slab between rafters.
I've done this before with 25mm pir, and tacked the celotex up first using clout nails, but I wondered if anyone's had experience using thicker pir insulation.....didn't want extra movement and cause plaster skim to crack 6m down the line.
Any advice very much appreciated.
Thanks all
Deano
Thanks all
Deano
