Plasterboarding advise please.
12 Jul 2008
Wiltshire
This may sound like a stupid question but I’m insulating a single skin garage wall, it’s still going to be a garage, I’m not converting it to a room.
The plasterboard is the foil backed stuff 8x4 sheet. The 50mm kingspan is also 8x4 sheets. What batten spacings do I use? Should I trim the kingspan down?
Thanks.
I’ve dot and dabbed the the rest of the garage as it’s internal walls so didn’t need to insulate.
This expanding foam, can I use it for insulation to brick then foil backed plasterboard to insulation? I could always fire some masonry screws though the lot as well?
