G
Greg20
Hi guys , (again, sorry for all the posts i always ask loads of questions),
My question is this :
Having looked at a job, i need to knock of various hollow/blown bits off 6 walls in a 12'x12' room(all above the skirting aswell, right around the room, as was ruined when skirting was removed), sort out, prep and re skim all the walls and the ceiling, the rest of which is sound.
Easy enough job, i think we'd all agree.
My only query is : One of the walls where ill need to knock off various bits and re undercoat before skimming, is an internal - external wall.
Im sure you understand
. The house is quite old, and has 2 skins of brickwork, with a cavity, though more likely 50mm rather then 100mm.
There are no signs of damp or anything, but the brickwork is like i said quite old. And past its best in a few places. Dusty, wonky ect.
On all the other walls i will prep, (dust down, pva, key, ect) the bits and then apply hardwall, in two coats as the plaster is certainly thicker then 11 mm.
On the internal - external wall though, who reckons i would be better and safer off, sorting out the patches which are down to brickwork, with a 4:1 sand and cement morter mix, rather then hardwall? Due to the fact it is old, and external.
Or do you think hardwall would be fine? (after correct prep work of course).
The brickwork is old commons, not engineering bricks or anything, so hardwall is the correct choice.
Thanks again for your patience everyone. I look forward to your intelligent replies.
Greg.
Greg.
