Plastering over damp bricks....how?
29 Sep 2003
Berkshire
Hi there, I am quite new to plastering (only done a little bit of "Patch work" in my own home), but a friend of mine has asked me to tidy up an internal wall which is prone to damp. The house is an old cottage! I have taken all of the loose plaster off (came off in patches) to reveal pretty damp brickwork (I presume rising damp) which I won't be delving into. However, my friend said that this has happened before in another area of the house and she said that the last person who plastered used a mix of plaster and UHU glue???? Has anyone heard of this?????
Basically what I am asking is: What is best to use for a quick reliable fix for plastering a few holes over damp brick? A packet of mix your own plaster and some glue mixed in?
Many thanks for reading.
Im afraid there is no quick fix ,you need to do it all or you will just be pushing the damp elsewhere
Sand. cement and a waterproofer but it's only a bodge really. You need to sort the damp issues.
1. As mentioned above, you will need to use a render mix such as 4:sand and 1:lime, no glues or cement necessary. Skim with a remedial finish.
2. As above, it will only be a temporary bodge; you must determine the cause of the damp and take it from there - research on here, there's masses of info. on precisely what you describe.
