Plastering under stairs?
29 May 2013
Lancashire
Need a bit of help in plastering the area where the floor meets the stairs at the bottom. Its like a V shape at the back. Just would like some tips.
Get rid of the V.
Fix a piece of timber to the floor, fix another small piece across the width of the stair/slope, then cut a 5", 6" strip of plasterboard, and screw it to the timber. That'll let the stair slope stop at the new vertical wall/strip you created. Just tape the joint and plaster away. You could even fit a piece of skirting to the new strip to finish it off,, you wont lose much space either. I did a similar job in our house where a shelf met a sloping ceiling, i built out onto the shelf a bit to make it square instead of the awkward V shape,, no probs. :wink:
