Thanls for that adviceI'll give it a bash!
Plaster should never go off on you that quick ; either you’ve used bad/outdated stock, over mixed it or not prepped whatever surface you’re plastering properly!Don't mix up more than you can get on the wall in about 20minutes, or it'll set hard on the board rather than the wall!
Not to my knowledge... I do remember the first couple of times i tried plastering, mixing up a whole load putting it in the board, then either spending so long trying to get it on the wall (and floor), it took far longer than i thought i would then looking at the board to find it had gone off!
Besides, if your only filling in holes, you don't need a massive load....keep it to small manageable gauges, waste less, spend less, and get used to mixing up!
No, my failing, was thinking of a seperate post.If you’re only filling holes (did the OP say that!)
Can't remember what it was made of! probably a piece of ply, or stirling board wetted before being loaded...Now i use a piece of old kitchen worktop.what was your spot board made of?
