on the main stack in the house, i have a plastic pvc plug that is on the main stack (which is cast iron). It came off yesterday and i sealed it back up with caulk. Toady it came loose again. How can i seal it back so that it does not come off again or leak?
when you say "plug" do you mean a bosspipe thats for a wastepipe???
that goes into the cast pipe??? If so i would use a strap on type that way it fits all around the pipe, and can be bolted on and sealed with silicon that will never come off,
