Plastic clip for attaching plinth
3 Dec 2005
Surrey
Hi, I'm trying to find some plastic clips to fit a plinth on a bathroom cupboard.
Not the ones that clip onto adjustable legs, there is a plastic pin, almost like the pin for a casement window stay, but plastic and not tapered, which screws to the carcase, and a plastic U shaped clip which is fixed to the plinth.
I've searched a few web sites, but I can't find anything. I guess I need to know what they're called!
Is it a spring push in clip type or hook in type?
Can you do a drawing?
Also have a look here
The clip part (screws to the panel) is almost like a white plastic Terry clip, and the mating is as I said, almost like a window stay peg. The second picture you posted would work, but it looks like you'd have a real struggle separating it!
Why not use steel Terry clips. You may need to put a spacer between panel and clip and a longer scew but it should make a good replacement for the missing palstic one.
