plastic flush cone pinging out
25 Nov 2006
London
Hello
I'm measuring up to fit a flush pipe to a back-to-wall toilet. I read to put washing up liquid on the plastic flush cone before pushing it in to the pan, but it kept pinging out. I've since rinsed and dried it and started again but it sits tight for a moment before slowly edging out. It's better with the cone on its own but even then it backs out by 3-4 mm.
I'm not using the full flush pipe, just a 15 cm cut off as a test so I know it's square. Is that normal? I read a rubber cone is better than plastic so should I swap it even before I've begun? Thanks
Washing up liquid on the cone is not a good idea. Have you also washed and dried inside the pan inlet?
Yes, but I'll do it again, it's still got a slight sheen on it. Thanks.
