Hello, everyone,
Would anyone help me with advice please? I'm replacing old basin in bathroom and have got new taps with standard flexible 15mm lead. On the other end I have a plastic tube which if measured with ruler give 10mm.
I bought two different brass reducing couplers. One 10mm x 15mm and another 12mm x 15 mm. The tap tube fits ok (15mm), but the plastic tube does not fit any of those two couplers. 10mm is too tight and 12mm is too loose. Is it possible that the tube is 11mm? Looks very non-standard to me.
I have some pictures.
http://tinypic.com/view.php?pic=n12hvl&s=8#.VI24GCtXcxU
http://tinypic.com/r/2zf34ba/8
http://tinypic.com/r/27yztw2/8
12mm is so loose that the whole tube can go through the coupler.
As for 10mm neither olive nor nut can fit the tube without applying some force and in that case the coupler just removes this extra mm of layer, which does not look to me right.
I see that there's 10mm plastic tube is popular on the market. Which compression fitting could fit 10mm if 10mm is too tight and 12mm is too loose?
