I have some UFH which is only 7m2.
The UFH heating consists of a suspended wooden floor, 50mm celotex between joists, pex-al-pex 16mm pipe 200mm apart filled with 25mm screed to top of joists. self levelled and then 22mm engineered oak glued down with sika bond. The UFH is a single loop with its own mixer, pump and stat.
The water temp from the other circuit is 65 degrees C.
To cut a long story short, i need to know what size plate heat exchanger i would need to heat the floor only. Or what would you suggest.
Dont worry about how its connected, thats not what im looking for.
Or could you please point me into the right direction as to where i could find out.
Thanks in advance
Thanks in advance
