Plate heat exchanger keeps clogging up
15 Jan 2020
Hi all,
my radiators work fine but every 6 months or so my water starts running cold (Halstead Ace High Gas combi). I get the heat exchanger changed and it's great again for another 6 months. When I drain the radiators the water that comes out is a little dark but not sludgy as such but there is visible black particles in the heat exchangers that are taken out. Incidentally, the system is always filled with inhibitor and a few years ago I got the system flushed but it didn't seem the have any lasting effect; there is a magnetic filter too.
My question is, what is causing this?, is one of the radiators disintegrating some how?, if so how can I ascertain which one?, I've considered getting a new boiler but am concerned that the problem may still be there and that will clog up too.
Any advice would be much appreciated.
Thanks.
Hi, thanks for the reply.
So I guess your asking which side of the heat exchanger is clogging up, truth is I don't know, until I looked at an unblocking video today I didn't realise the 2 sides had separate flows. I'm in a hard water area.
PS. most radiators are of a newish type- double wall with vent thing over the top edge, there are a few which are the older type but nothing ancient.
Suppose you could try installing a magnetic filter on the return to the boiler, but to have to fit a new plate heat exchanger every six months would indicate a very dirty system which you dont seem to have
