Something wrong with the pic of the door and step, the plinth should be below the dpc which should be below the door threshold, yours clearly is not.Either plinth is too high or the door is below the dpc, which is unlikely.
you tape a clear piece of plastic tightly to the wall.
You`ve got flooring and carpet there ( for your storage ) then a thick insulation - the insulation is fine , the flooring and carpet aren`t Previously you mentioned the loft was full of conden. - you need to clear the loft and let the moisture come up through the ceilings and get blown away - Harsh , maybe but exactly what I had to do in my present bungalow I do have a small storage area but it`s well above the top of the insulation . The place was riddled with mould when we bought it ( got it cheaper because of that ) Those metal air vents - do they actually go straight through to the underfloor ( I`m assuming it`s a wooden floor ) Mine didn`t - they kind of offset through the cavity - until I got under the floor with a hammer+chisel . Also where do the rainwater pipes go , maybe into old broken pipes underground , letting water sit around the house . Have you got an open fire - that`s a good one for ventilation ( had to uncover and re instate ours )Put Xmas decs in loft, so had a good look round up there too. Smells a little 'musky' but no wet patches. Checked the front of house roof support wall, no sign of any leaks or any wetness at all.
that`s a good description[ Like a rough rubbery line of pointing?
