Please help with boiler prob
11 Sep 2005
Today i drained the system and swapped a rad from one wall to another.
This is what i did.
Unscrewed rad and drained the system
Cut pipes below the floor
fitted pushfit fittings and ran pipe to other wall.
Connected piped to rad.
Went to represuurise the system
My boiler has completely shut down. I am getting no hot water from my taps. I turn the small valve to let water into the boiler but it sounds as if nothing is coming through. I have checked the water supply to the boiler and its fine. Before i drained the pipes i didnt swithch the boiler completely off. I turned off the central heating but not the whole power supply etc.
When i turn the boiler back on it just flashes red with a pressure reading of 0.0. I turn the valve to let the water into the boiler but there is nothing happening.
Its a glowworm 24ci.
Many thanks
just open it up until it starts to fill....is the glowworm ci the one with the inbuilt filling loop and the little blue knob to turn to open it?
Cheers for the reply,
\yep thats the one. it has a small blue plastic filling thing
