Hi i'm going to change a towel rad for a normal one and just wanted some advice as to if i'm going about it the right way, the boiler is a worcester 28cdi combi.
turn off boiler and make sure filling key is turned off
turn trv and lockshield valve to off position
disconect valves from rad and drain water off
drain off some water from drain off valve on rad downstairs
remove valves and move pipes to fit new rad
hang new rad upstairs and connect valves to pipes
fill system up with water
bleed new radiator and refill with water until correct pressure
i would apreciate any help if this is wrong,also can someone tell me the correct presure for this boiler its about 0.8 at the moment this seems a bit low. thanks
