Hi All,
I hope you can help - I seem to have a pretty bad problem.
Two nights ago our circuit breaker tripped, which tripped the main breaker and plunged the house into darkness. Obviously I lowered the problematic circuit and switched on the rest of the electrics. No problem.
However, the problem circuit happens to have every single socket in the house (over 3 floors) attached to it - so effectively we have no fridge, TV, kettle, oven, phone, etc etc etc.
We also have had some issues with Damp in our lower ground floor and initally I was thinking this was the problem as one of the sockets had damp surrounding it. Therefore I have taken the socket panel off the wall and sure enough there was a substantial amount of dirty and rubbish in the box - I cleaned up the contacts the best I could using a plastic knife and left the face unattached to the back, hoping to dry out the wire (not that they sparked or appeared damp in anyway. I also unplugged everything from the circuit over the 3 floors (oven, fridge, washing machine etc etc)
I left the problem circuit off a few hours and then switched it back on - all was ok for about 24 hours, it's now popped again, and I'm beginning to have my doubts regarding the problem socket. I've even swapped the circuit breaker to another 32 amp one, but the same problem arises.
I've bought a termination block, and I've attempted to unwire that socket and terminate the live, neutral and earth wires onto it - I have 3 wires and I terminated each one into a seperate hole on the block (is that correct?!?)
Question is, if it is that socket, how do I safely contain it and get the circuit back up. If it isn't that socket then what can it be?
I've performed zero amount of DIY over the past few months, so it cannot be new nails, or me messing around with everything...
Please help! I'm reluctant to phone an electrician at this time, as I don't want to be ripped off.
