Hello
I am planning on fitting a Smiths SS5 hydronic plinth heater in my kitchen.
The central heating system currently only has a radiator in the living room and the rest are upstairs. The tails to the radiator downstairs are in 10mm microbore. The radiator is at the opposite end of the living room from the kitchen. Running pipework from this radiator/pipework would be difficult due to both the distance and layout of the room.
The boiler is in the kitchen and is quite close to the area where the plinth heater is to be fitted. The flow and return on the boiler are both 22mm and leave the boiler and go up into the ceiling above it. It would be much easier to tee into these pipes and run the pipework for the plinth heater the short distance down the wall and under the units. My only concern is that chopping into the system so early (before the pump) on these 22mm pipes and running the pipework across the top of the door and down to the plinth heater (which I have read is very restrictive) and then back up (the whole height of floor to ceiling) for the return may pose problems for even flow throughout. Would it be able to push the return flow back up?
Does anyone have any experience of this and whether or not I should tee into these 22mm pipes? If I do, what is the best size of pipework to use for the plinth heater both to keep flow equal and provide the plinth heater with enough heat?
Cheers for any help
Ray
Cheers for any help
Ray
