Thanks mate. I ordered the tiles today and bought the stuff from the same place. It is described as "Epoxy flexible joint". The sales girl explained it is an epoxy product, using a hardener ?? Never heard of it before, but she swore by it and at £36 for 2.5kg, it aint cheap either, so it better be good.
Does it go on the same as 'normal' grout ? And more importantly, does it clean off, like normal grout, or is it a bit more difficult to use ?
I was also concerned that I would have a pretty limited window to use it, before it starts going off and the fact that I won't be able to mix a small quantity if needed, due to the mixing ratios etc ?
