Plumber in Liverpool ( Fenox TF1)
5 Feb 2007
Liverpool
Is there any plumbers on here or close to Liverpool that fits Fernox filter ?
I have filter just need fitting.
No one interested in this job, got photo of the boiler where it needs fitting or can call to look at job ?
Get a picture up.
Can i ask why you have already bought the product? It leaves you at a disadvantage, because if it leaks a few week after install due to manufacturing error, then the burden is on you, not the plumber.
It's all in the Sale of Goods act
Ill get a picture up in a hour or so its on my phone, I will take product back then no problems and give quote with valve please .
Plenty room there. :eek:
Andy
My thoughts exactly, it's not a plumber you need mate. It's a gynecologist. :eek:
Assuming you did manage to get one shoehorned in where you want it, how are you going to clean it?
I was thinking of removing the whole cabinet then having the plasterboard cut above to make space for fitting the filter, then cutting a section out of the top of the cabinet where the filter is to re - fit cabinet again. This way I should be able to clean the filter. At very worse case scenario I would be able to remove the cabinet to have better access to clean filter. The cabinet is only two screws on l shaped brackets to slide it out.
Will this work and does anyone want the job ?
I can remove and replace cabinet if you think you can fit the filter !
Also as for cleaning it if a Spirotrap was fitted this should be able to be cleaned as I believe the valve only opens at the bottom and you can attach a hose to drop into bucket so shouldnt need that much space to atatch a hose.
No ?
Can anyone tell me that there is no way I can have one of these filtesr fitted in this space with doing what I said ? Just done a Fernox restore on system and its running with no inhibitor in as I knew it would have to be drained again for filter. If it cannot be done I can just go and get inhibitor in straight away.
