plumbing and central heating
14 Nov 2005
Kent
hi im fitting new bathroom suite and want to know is it ok to fit toilet over laminate flooring or fit toilet and cut around it? thanks in advance
It looks a lot better if you put the pan on top, though it's often done the other way. Usually a rather ugly bead of silicone comes in.
Didn't know there were laminates which you could use in bathrooms - what about the water which you will get on it, however hard you try not to!?
