    Dismiss Notice
Plumbing in a shower help needed - 15mm pipe to this fitting
Discussion in 'Plumbing and Central Heating' started by adambrownb, 26 Mar 2011.
  1. adambrownb
    adambrownb
    22 Mar 2011
    22
    Thanks Received:
    Kent
    Country:
    Hello,
    I've just bought a new mixer shower. My pipework coming out of the wall is 15 mm and I need to be able to find a fitting which will then screw around the fitting in the picture which I believe is 22mm and form the seal. Is this possible?
    Adam
    [/img][​IMG]
  2. Sponsored Links
  3. Jake1886
    Jake1886
    28 Jul 2010
    470
    Thanks Received:
    44
    London
    Country:
    Its a bent male copper/iron
    You need to insert a 15mm pipe with a nut and olive on and insert into the fitting. The nut will then tighten onto the thread with the ptfe on and compress the olive and form a seal.
    Hope this helps.
  4. adambrownb
    adambrownb
    22 Mar 2011
    22
    Thanks Received:
    Kent
    Country:
    But the 15mm pipe is too small? Will I need to extend the pipes that come out of the wall?
  5. Jake1886
    Jake1886
    28 Jul 2010
    470
    Thanks Received:
    44
    London
    Country:
    Are you saying that you haven't got enough pipe coming through the wall? Or that the pipe is too small for the fitting?
  6. adambrownb
    adambrownb
    22 Mar 2011
    22
    Thanks Received:
    Kent
    Country:
    I've got enough pipe coming out of the wall. The pipe is only 15mm and the hole in that fitting is a lot bigger
  7. Jake1886
    Jake1886
    28 Jul 2010
    470
    Thanks Received:
    44
    London
    Country:
    That case you have a 22mm x 3/4 copper to iron. You'll need a 15mm x 1/2 bent male copper to iron.
    Little difficult to tell what size fitting you had by the photo mate.
  8. xr4x4
    xr4x4
    1 Oct 2009
    3,159
    Thanks Received:
    290
    Hampshire
    Country:
    Can you replace the fitting you have in your hand for a 15mm fitting?
    Ie a 22 to 15 fitting?
  9. adambrownb
    adambrownb
    22 Mar 2011
    22
    Thanks Received:
    Kent
    Country:
    But the bottom half of that then needs to screw into the shower, so will that still work?
  10. Sponsored Links
  11. muchsoonerbesailing
    muchsoonerbesailing
    10 Dec 2010
    6
    Thanks Received:
    Kent
    Country:
    What you appear to be holding in you photo is a Bent Male iron to copper fitting probably 22mm x 3/4". The simplest converter is a 22mm x 15mm compression reducer kit made up of three components, The bigger insert goes into your fitting first followed by the olive and lastly the thinner insert. All three components fit snugly together held in by the original nut (not shown in your picture). You could use a smear of jointing compound too. All should cost about £1
    good luck
  12. adambrownb
    adambrownb
    22 Mar 2011
    22
    Thanks Received:
    Kent
    Country:
    Cheers, is this something I will be able to buy from B&Q?
  13. muchsoonerbesailing
    muchsoonerbesailing
    10 Dec 2010
    6
    Thanks Received:
    Kent
    Country:
    Wicks, Payless, focus, B&Q, homebase, Probably, just treble the price!
  14. adambrownb
    adambrownb
    22 Mar 2011
    22
    Thanks Received:
    Kent
    Country:
  15. muchsoonerbesailing
    muchsoonerbesailing
    10 Dec 2010
    6
    Thanks Received:
    Kent
    Country:
  16. adambrownb
    adambrownb
    22 Mar 2011
    22
    Thanks Received:
    Kent
    Country:
    Cheers, I could do with buying it tomorrow but can't seem to find it on homebase or B&Q's websites.
  17. Jake1886
    Jake1886
    28 Jul 2010
    470
    Thanks Received:
    44
    London
    Country:
    You can buy reducer sets from screwfix, they will obviously be open tomorrow. Happy days!
Loading...
Share This Page
