plumping
21 May 2005
Glasgow
I need to use a reducer from a 15mm to a 10mm
compression fitting for a new radiator how do you fit what where.
if you can not figure that one out then i suggest you should not be doing the job
lift floor board fit compression fitting out of site. bring 10mm pipe up through floor board
If you apply the same concentration to doing the job as asking the question you will end up with more leaks than Taffy's garden :!: :!: :!:
Get a plumber in to do it!!!
