Hi i have built a gardenroom and want to put plywood on the walls and ceiling inside and wanted to know if 9mm plywood will be thick enough for this as i already have several sheets of this.
i don't think i need to double board it i have 15mm cladding outside double battens giving 50mm air gap, wrap then 11mm osb then 4 x 2 filled with insulation.
