Pneumatic flush concealed WC
1 Oct 2012
Edinburgh
Hi
I have an issue with a concealed WC, the air tube from the push button to diaphragm(?) pops off on the latter side. If you hold it in place, flush works fine.
Normally I’d think some sort of jubilee clip could work but diameter of tube too small. It’s also difficult to get a close look at the connection.
Any suggestions?
How about these clips, many other similar listings as well.
A 'garage' may have some, as I have seen them used on petrol fuel pipes.
+1 to try shortening pipe slightly. Or even A new length of pipe if too short. They may well come in different diameters, I suspect, for different brands.
A very small ty-rap might help.
An aquarium shop may have something to suit as similar small pipes are used for oxygenation.
On closer inspection I found air pipe actually slots into a cm long sleeve, which is also soft plastic. As this connection is above normal water line I’m going to try superglue and the plastic ratchet clamps (9-10mm size) suggested above. The aquarium shop also a good shout!
