Polyfilla vs caulking
26 Jan 2009
Middlesex
I have a couple of cracks in a wall (emanating from the corners of an isolation switch). Not are about 250mm lond and about a mm wide. the wall is plaster on block. Woudl I be better filling them with Polyfilla or decorator's caulking?
7 Feb 2008
Northumberland
Polyfilla can be sanded, whereas decorators caulk can't....thats used for filling on top of skirting boards etc where you can smooth the stuff with your finger. Polyfilla for you! Press it in as far as you can then sand down when dry. Open the crack out a fraction if its really fine.
John :)
25 Oct 2008
Cheshire
If the crack is deep, I also find decorator's caulk suffers more with shrinkage. So you'll be left with a hollow when it dries.
Agree with Burnerman - polyfilla better for your suggested issue.
1 Mar 2009
Buckinghamshire
Omw yes,forget to mention it, Red Devil onetime filler is the absolute dogs b*****s, Ive been using it for years, pricey but great stuff - slightly flexible too ..
Not suited to larger areas needing skimming though (unless youre rich )
16 Jun 2006
London
Have you seen the prices at TLC-Direct???
I haven't seen it that cheap since Nu-Line w.11 used to flog it at £13.75 (ages ago)- its about £21 in my local merchants
1 Mar 2009
Buckinghamshire
..mmm.. Those prices for Onetime are no better than I get at Brewers with my trade discount...
Whats this Toupret stuff like to use in comparison?
