Hi guys
I have a Potterton Performa 24, probably about 7/8 yrs old. Central heating has always been fine, but hot water has always been a problem. Even 5 yrs ago, when i moved in, if i opened the upstairs HW taps fully i would not get properly hot water. As such, I have always had to minimise the flow rate.
I've lived with it till now, but now it's really bad! The other thing to note is that the large burner flame will usually switch off before the water gets really hot. It seems to cycle on-off a bit too frequently now.
I've checked out some other posts and it looks like it could be the Plate Heat Exchanger, where hard water can cause scaling. Does this sound right? I've checked that the heating flow pipe stays cold (to rule out the Diverter Valve). Are there any other possibilities? I've even been considering getting a new boiler as i'm that annoyed with it!
Thanks for all advice.
