Does anyone know how to safely remove the bit that you twist (just below the taps) to open the plug on this type of pop up waste mechanism?
It's very similar to this:
http://www.ec1bathrooms.co.uk/ishop/1138/shopscr957.html
It has stopped working in that you can twist the knob but the plug doesn't lift. I have bought a replacement and I can see how that works as there is a small hole in the knob where a screw can be reached and undone. However, on the current one, it is solid all the way around. I can't find an obvious way of removing it.
Cheers
Cheers
