I raised this problem on the Electrics UK forum a couple of days ago and the guys over there were extremely helpful in enabling me to get a much better understanding of the issue.
However it now seems to have run its course on that forum so I am hoping that someone on here may be able to help me take it to completion !
In summary, I carried out some building work a few weeks ago, part of which involved me taking down and rebuilding a stud partition wall where the power supply and timer switch for my central heating system where located.
I was very careful in that I took photos and made notes about the wiring so that I could put them back exactly as they were.
I was pretty sure I’d done that – but when I switched the power back on, whilst the timer came on – the green LED on my Baxi 100 HE didn’t.
I called out British Gas in case it was boiler problem – but the engineer managed to blow the fuse in the power supply when he manually moved one of the valves.
He then told me I had an electrical problem – and left !
I’ve checked, double checked – and triple checked all of the wiring.
I’ve also followed back the wires to my main wiring centre (I have an ‘S’ plan set-up) and pretty much everything appears as I would expect.
The only exception to this comment, is the blue wire in the timer cable, which for some reason, appears to change to an earth (G/Y) before it is sent on to the boiler ! (the boiler only has a switch live - no permanent live).
However, this has always been the case – and I have photographic evidence to prove it !
Whilst I originally thought that I must have wired up something incorrectly, I am now wondering if the problems (lack of power to the boiler and the power supply fusing) could be caused by a fault in the timer ? (it is an old Honeywell ST6400C)
I am trying to contact an electrician to take a look – but I am struggling to get a reply…
All help/comments gratefully received
