I know it is too late for this year but I want to think about a mega Xmas lights display for next year.
I was thinking of just doing a couple of external sockets through the wall from internal ones (with RCDs of course) but have changed this to having a new, but external ring main installed instead. Have got spare slots available on modern fuse board.
I have however got a few questions if that is ok, as I do not want to look silly with my electrician
1) Can a ring have a combination of lights and sockets or does it have to be one or the other.
2) I wanted to have a combination of external sockets at foundation height and the weatherproof boxes higher up that have the multi extensions inside, or will that cause a problem. Would I be better off having an external socket immediately next to the weatherproof boxes rather than wiring the extension lead into the ring (from a replacement point of view later on)?
3) Is there any way of getting an internal switch or even a timer switch that could control the whole circuit? Possibly both so that it can be switched off in summer and timed in winter?
4) Will the RCD on the main fuse board be enough or will I have to have a RCD hard wired into the circuit?
Think this is all I need to know about for now but will add if I think of anything.
Thanks in advance for all your help and yes I will be getting a qualified sparky to do all of this !!
