The radiator in my living room has been faulty since I bought the property two years ago. It's warm-hot at the top and cold at the bottom, which is the opposite of the common 'it needs bleeding' issue. I have bled it anyway, just to be sure. I'm suspecting that it has 'sludge', a build up of gunk at the bottom of the radiator.
This is the last radiator in the system and the feed pipe to it is scolding hot, however the return pipe is luke warm at best. All other radiators are working perfectly. The common fix for sludge in a radiator is to remove it and blast it out with a power washer or clean/flush the entire system. Both of which appear to be more expensive than just replacing the radiator
My question is; Do you think replacing the radiator would fix the issue? I wouldn't be doing this myself, I'd be getting someone in to do it. I don't really want to spend the money, only for it not to fix it.
