Hi, laying a new block pavor driveway however my house has very shallow foundations and drains. I have put a picture in so you can see the lay of things.
The drain is clayware and directly below usual vehicle track and has a capped spur running quite close to the topsoil.
So first question would be am I best to encase the section of the drain in the concrete haunch of the edge course, or leave a certain amount of pea shingle type bedding around the drain and have a more shallow haunch over that section? (the edge course here will abut up to a footpath/roadway so pavingexpert says ok to go to 50mm here)?
Next question is about the foundations. They're only one or two bricks deep. So I have the option of running an edge course & haunch right against the foot of the wall which would be good for the foundations I assume but bad for damp (it's also a high ground level to internal floor), with no section of pea shingle as a drain off or work like normal and separate the edge course and leave a section for drainage. What do you think should I be concerned about the foundations or not?
Final question is back to the drains, for the main section that will lie under the sub base, it's still quite shallow and might not allow for 150mm sub base plus blinding layer etc as well as separate smaller bedding for the drain. Am I best to encase them in smaller bedding and have a shallower section of sub base over the drain line or have people got no concerns about MOT1 going directly onto drains?
Probably turning this into more of a drama than need be but then I'd rather not have to dig up a turd laden driveway with a subsiding house over it! Thanks
