Posts for raised decking
10 Jun 2012
Cleveland
Hi guys
I'm planning a raised decking area on a sloped garden, the back of the deck will be ground height and the front about 400mm off the ground, area is 4000×4800mm.
Looking for opinions on supports, I have some lengths of mild steel channel, 50×100×50mm which is 2.5mm thick, would this be better or just as good as using 100×100mm treated fence posts?
I've got a big tin of hammerite spare that I can paint the channel with for a bit of extra protection!
Cheers
If it's going to be upright and concreted into the ground then the metal will outlast the wood (y)
Cheers Nige,
So you think the steel will be better, I wasn't sure with it being only 2.5mm thick, I didn't know how long it would take to rust away and snap under the weight!
