Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
That would be correct assuming the void is ventilated. I still think this is overkill for a shed. You may be heating it, but unless you're living in it where will the moisture come from? Condensation is caused by moisture held in warm air condensing out when the air is cooled, as cold air can hold less moisture. Why are you heating it? Will you be working in it?
Yeah that would be fine, one time i bought some i think Screwfix and it was literally silver parcel tape, i took it straight back for a refund. So be careful it's actually foil.
Yes tape all the edges, ideally use the wide tape to cover the joist completely. Idea is to stop up any possible gap or crack. Also tape the insulation to the adjacent wall or insulation. And foam in any awkward gap first
