pott promax he
25 Jan 2007
Yorkshire
anybody know any known faults with this boiler?
This one works fine for hours on end then just cuts out and has to be reset to start again? (Was thinking of the pott suprima board fault and wondered if these may have same or similar fault)
Common faults with these are gas valves, electrodes, combustion door seals, oh, and anything else.
since they were produced. Nice to see you didn't disagree with the other common faults :wink:
has done it since new, but not that often. heard door seals can be a problam, which is most likely?
The sequence of lights displayed will point you in the right direction.
No lights? remove the outer case.
