Hi Guys,
Over the past week or so I've noticed a problem with my bolier. The radiators have only been getting luke warm and the water hasn't been very hot. All in all it seems like the boiler isn't igniting, if the heating turns on it can be 10 - 15 minutes before the boiler sparks and ignites. Once running its fine, its just the initial startup.
Is the pilot light mean't to be running all the time on this model or does it turn off when not running?
It sounds like the fans are kicking in and then you hear a tick as if it should be sparking but theres no visible spark
The thermostat in the room is on full and the pump seems to be working ok. I assume this is an issue with the ignitor or supply?
Any suggestions appreciated, I'm a novice and don't know alot about boilers, before I call an engineer just wondered if theres anything I can try
Thanks.
Thanks.
