Potterton 25 year old boiler myson pump
  • Thread starter Thread starter ct4
  • Start date Start date
ct4
6 Oct 2005
London
works fine but upstairs is warm downstairs radiators are cold,bleed the radiators ,closed valves upstairs on radiators on one side still cold downstairs.
called plumber busy said try the pump black plastic hex opened it up pulled it and turned any which way i could burning hot.
sparks start too fly burning smell plastic burning at bottom rear switched timer off and thermostat, switch on hot water same burning smoke switched everything off .
Any ideas ???
The sparks might be a clue here. :idea:
I don't suppose you do a concise version for texting ??
should i go fo wall mount as the old one is floor standing?
Potterton Kingfisher MF RS RS100 (Reference #106056)
100,000 Btu's
Dimensions:-
High - 850mm
Wide - 290mm
Deep - 520mm
Requires Flue (see bottom of page).
Price Includes Delivery
Click here for Potterton Kingfisher MF RS RS100 Tech Spec
Price ex VAT: £1,046.59£1,229.74 Including VAT at 17.5%
