I have a problem with our potterton performa 28 boiler.
it works fine except in the following instances.
when the central heating is on, and if the hot water is turned on from the tap. the boiler switches off i.e. the flame failure light turns on. the only way to bring it back is to reset the boiler and the it then works again immediately.
throughout the day, if the heating is not being used and the hot water is turned on, this functions/works fine.
any ideas on what is causing the problem?
Is this a quick/cheap fix?
Ta.
Ta.
