I need to see if anyone on this forum can help with my problem.
Our Performa 28i keeps giving us a flame failure when set to Rads/Taps. We can stand there and reset it endless times but with the same result. After leaving it for a few hours sometimes it will stay alight but as soon as the Rads need more heat or the hot taps are turned on then off we get the flame failure.
If I reset the system and switch it straight over to Taps only the boiler if fine and heats the tap water everytime!
Someone has mentioned that it could be the PCB board (part number 248074), but I have had a look at that and nothing seems a-miss. Before I go and spend £85.00 on a new PCB board, which I will not be able to return if it's not the cause of the problem. Can anyone suggest anything else it could be or if it is looking like the PCB board can I get fully working one any cheaper?
Cheers.
Cheers.
