Hi All
My daughter has just move into a property with a Potterton Combi boiler.
Central Heating and Domestic Hot Water are working fine, but the CH pressure gauge raised to over 3 bar and the pressure vent was opening.
With CH switched off I bled a radiator to reduce the pressure, but it would not reduce to below 2 bar, I assumed the closed system was being continually fed from the mains.
On checking the boiler isolation valves, all the coloured valves were 'open'.
Eyeballing the layout I assumed the inner blue valve is the one which is used to 'top up' the CH system.
I closed the valve and managed to reduce pressure to 1 bar (cold), Run the CH for a while and the pressure only raised a little further.
Grateful if you would check the attached pics and confirm the valve
configuration is now correct?
Cheers All.
configuration is now correct?Cheers All.
