Everytime I turn the boiler on, the green light comes on and burner starts burning automatically without any demand for heating or hot water, and then it locks out. Also few drops are dripping from DHW switch.
Thanks for your reply, I have checked and its not short, I have put a plastic sheet below the switch so that leaked water goes out without falling on anything inside the boiler. What else can be the cause. Really appreciate your response.
Thought so. I mean we all thought so. That comes on to indicate a hot tap water flow - so the switch has probably had water in it and is looking like it's closed. Pull a lead off it!
The manual is here http://www.partsarena.com/baxi/
Switched Live is one of the main boiler input connections. It's what turns the boiler on for CH. You would typically measure the volts (mains) on it with a multimeter. Not really a suspect now, but I'd check it anyway.
The problem lies with the dhw switch witch is a sealed unit and can only be exchanged with part of the wiring harness. You will also need the pressure differentional so call baxi.
