Potterton Combi 80
3 Aug 2006
Hertfordshire
Had the usual blown pcb on one of these today, but when taking the pcb out, the top left lead (the power one) had a pin stuck init from the old pcb. When I removed it (which was difficult enough) it seems to have removed a metal strip from inside the connector block
Can this block be fixed or a replacement brought? What are my options?
Thanks as usual guys
A total bodge is to use a chocolate block single connector for just that pin.
Another bodge is to connect that wire to another one connecting to the same ( neutral I think ) line on the PCB.
Another bodge is to heat up the connector plug and ease the female connector back in using some additional plastic if need be ( from that choc block for example ).
Tony
Would that part of the connector block missing stop the pcb from functioning?
Also, what do you mean by using a chocolate block single connector for just that pin?
kevplumb said:
if yer dunno what you are doing fella
put a new board in :wink:
I have put a new board in, but the connector block (PL1) that plugs onto the top left of the pcb is slightly scorched and has the inner metal strip missing. Hence my question!!! :D
Ok so.......
and.......
Would that pin (furthest to the left of P1) not touching the board stop the board from functioning?
newcomers said:
Ok so.......
and.......
If you've damaged the connector then it needs replacing. I dont think you can get away with using a single choc block. That IS bodging!
Ring around and get a spare one if its not listed then try the smaller places
they should stock them. I get mine from the old ones the installers remove.
I done one today funnily enough and yes you do need it unless its a black or purple wire and you have an integral timer. I think thats what these are for.
PL1 [Potterton part number]
21/19018 CABLE ASSY. MAIN
GC 289697
PL1-MODULATION CONTROL BOARD WIRING HARNESS INCLUDES TERMINAL BLOCK AND OTHER CABLE ASSEMBLIES
