I went to a house this afternoon to look at a leaky wc. Whilst there the fella told me he had a problem with the heating.
I'm a bit out of touch heating wise, heres the situation.
500 year old cottage, 10 year old extension, 5 bedrooms, 19 radiators. pumped (15-60), floorstanding balanced flue kingfisher boiler, unvented hot water. 50/50 old rads/new rads, TRV's each rad, programmer, roomstat.
He says when he puts heating on the boiler fires up and seems ok but all the rads on one side of the house (5) dont get hot (or warm even). These rads are the furthest away from the boiler. After a while (assume when most rads reach temperature) the boiler turns off. The boiler will not fire back up again unless he switches the programmer off then back on again. When the temp drops the stat clicks but it still doesn't fire up.
The pump works ok, as do the motorized valves.
Is this more than likely the boilers not big enough (26kw) struggling to reach the furthermost rads, or something more sinister??
Thanks in advance.
Thanks in advance.
